Steady State AC Electric: solved equations
Introduction
In a Steady state AC Electric application the equations used for computation are:
- the corresponding Maxwell's equations for an electrical system, and
- the constitutive equation that characterizes the dielectric materials
The conditions of computation of a Steady state AC Electric application are the following:
- the computation concerns the D and E fields; the B and H fields are not computed. The equations of the electric fields E, D and of the magnetic fields B, H are decoupled.
- the fields are harmonic time dependent of the pulsation ω. In the complex form of the equations, the operator ∂/∂t is replaced by the multiplicator jω
Equations and conditions
In the previously defined conditions of computation, the equations in complex form are summarized as follows:
                            | E : electric field strength (in V/m) D : electric flux density (C/m2) V : electric potential (in V) J : current density (in A/m2) |
 | σ : conductivity (in S) εr : relative permittivity ε0 : vacuum permittivity (in F/m) |
Reminder about the differential operators: The curl divergence of a field is always null: div [rot (Field)] = 0.
Solved equation
The second order equation solved by the finite elements method in Flux in case of a Steady state AC Electric application is the following:
where:
- [σ] is the tensor of the conductivity of the medium (in Siemens),
- [εr] is the tensor of the relative permittivity of dielectric materials
- ε0 is the vacuum permittivity; ε0 = 1/(36 π 109) (in F/m)
- V is the electric potential (in V)
State variable
The state variable in a Steady state AC Electric application is the electric potential V (written Ve in Flux 3D). It is a complex quantity.
The uniqueness condition of the scalar field of the complex electric potential V requires that the value of this potential at least in a point of the computation domain be known.
Complex permittivity
The permittivity ε is a complex quantity that takes account of the frequency:
[ε] = [ε']- j [ε'']
where:
- [ε'] stands for the real permittivity, and
               [ε''] stands for the dielectric losses constant: [ε''] = [ε'] tan δh (with δh angle of hysteretic losses)
The second order equation solved by the finite elements method in Flux in case of a Steady State AC Electric application is the following:
