Cut geometric objects
Cut a geometric object
To cut a geometric object:
| Step | Action |
| 1 | Open the dialog box:
| → | The dialog box Select cut plane is opened. |
| 2 | To cut one or several geometric objects:
| 3 | Confirm: by clicking on  |
| → | Cutting sheets are created at the places where the objects can be cut. The dialog box Select cutting sheets is opened. |
| 4 | To continue the cutting of the geometric object(s):
| 5 | Confirm by clicking on OK |
| → | The new objects are created as a result of the cutting. |
 or
 or
