Volumetric heat capacity, exponential function of T + Gaussian of T
Presentation
This model defines a volumetric heat capacity ρCp as an exponential function of the temperature, taking the energy of phase transition (Curie point, ...) into consideration.
Mathematical model
The volumetric heat capacity is the combination of an exponential function and a Gaussian function of the temperature.
The corresponding mathematical formula is written:
 with
where:
- ρCp0 is a constant the volumetric heat capacity at T = 0 °C (J/m3/°C)
               ρCpi is another constant the volumetric heat capacity at T = infinite (J/m3/°C)
- E is the energy of phase transition (J/m3)
- σ is the typical Gaussian standard deviation (°C)
- TC is the transition temperature (Curie temperature, …) (°C)
- τ is a temperature constant of the exponential function (positive or negative) (°C)
The shape of ρCp(T) curve is presented in the figure below.
