Magnet (unidirectional): demagnetization curve (Hc, Br) + knee
Presentation
This model ( Nonlinear magnet described by H c and the B r module, plus knee adjustment ) defines a nonlinear B(H) dependence with taking into account of demagnetization and knee adjustment .
Main characteristics:
- the mathematical model and the direction of magnetization are dissociated
- a single material for description of several regions
Mathematical model
In the direction of magnetization the model is a combination of a straight line and an arc tangent curve . A coefficient adjusts the shape of the curve knee for a better approximation of the experimental curve
The corresponding mathematical formula is written:
with
where:
- μ0 is the permeability of vacuum, μ0 = 4 π 10-7 H/m
- μr is the relative permeability of material (for H = Hc)
- Hc is the coercive field strength A/m
- a is the knee adjustment coefficient (0 < a and a < > 1)
The smaller the coefficient, the sharper the knee is.
- Js' is computed by dichotomy from Br, Hc and μr, with the equation
In transversal directions one can write:
B⊥(H) = μ0μr⊥H⊥
where μr⊥ is the transverse relative permeability
Direction of magnetization
The various possibilities provided to the user are the same ones as those presented in § Magnet (unidirectional): linear approximation.
