Assign a mesh generator to faces / volumes
To assign a mesh generator to faces / volumes:
| Step | Action | |
| 1 | Activate the Assign mesh generator command (see next block) | |
| → | An assignment box is open. | |
| 2 | Fill out the assignment box:
| → | The mesh generator is assigned to faces / volumes. | |
| 3 | Go on assignment:
 | Quit the assignment sequence:
Activate the command
To activate the Assign mesh generator command, which requires data selection, choose one of the methods presented in the figure below:
- To open a contextual menu, use the right button of the mouse.
- For multiple selections, keep the Ctrl key pressed.
