Create a custom role for your site.
                Click .
                Click Roles from the Access Management menu located on
                    the left-hand side of the web page.
                Click Add Role.
                A role is created with a default role name and undefined
                    privileges.
                Click  located to the right of the name of the role. located to the right of the name of the role.
                        For Role Name, enter a name that describes the role.
                        Click OK.
                Choose System Administrator privilege if you want to
                    provide full permission.
                By default, only Application User privilege is provided
                    to the new Role.
                Click  at the top next to the
                    Assigned Resources. at the top next to the
                    Assigned Resources.The Available Resources menu is
                    displayed.
                Choose the resources to give to this role by clicking the check-box located to
                    the right of the resources.
                Resources are not mutually exclusive, so you may assign more than one.
                Click Ok in the Available
                    Resources menu.
                Click Save.
                The new role is displayed in the Roles list.
