Uploading Data Extracts
Users with a Designer role can upload data extracts to folders where they have permission.
1. On the Data Extracts page, click on a folder or a personal folder and select Upload Data Extract.
The Upload Data Extract dialog displays.
2. To upload a data extract, you can either:
· drag it from your desktop and drop on the dialog, or
· click Choose Data Extract and select one on the Open dialog that displays.
The name of the data extract is displayed on the uploaded data extract area and in the Name box.
3. You can opt to rename the data extract.
4. To replace an existing data extract, check the Replace existing data extract box.
5. Click
You will be notified once the data extract is uploaded.
The data extract is uploaded and added in the designated folder.
