Creating Folders
A user with a Designer role can create folders.
NOTE |
Users that log on with a Designer role: · will have their own personal folder created and displayed on the Workbooks page (e.g., ~designer). This personal folder is where Designers can create workbooks and build dashboards. · is not allowed to create a folder on the root folder.
1. On the Workbooks tab, right-click on the personal folder, and select New Folder.
The Create Folder dialog displays.
NOTE |
· The Designer user is available under the Allowed section by default with Read, Write, and Modify permissions. · Removing the Designer user will mean they will not have access to this folder and its subfolders.
2. Enter a Folder Name.
3. Proceed to defining the Authorization to Allowed or Denied groups and users.
4. Click
The new folder is displayed on the expanded Folder hierarchy list and on the Folders/Workbooks list.
NOTE |
· Folders and subfolders can be deleted as long as they do not contain published workbooks. · The folders and subfolders on the Workbooks tab will also be available on the Extracts and Webhooks tabs.
