Deactivating Monarch Using the Altair License Management System
If you activated your copy of Monarch using an Altair Activation Key, you can deactivate your Activation Key via the Altair License Management System.
In Altair Monarch License Manager, select the Connect to an Altair License Management System option in the Choose License Method screen and then click Next.
Select the Activation tab in the Altair Units License Configuration screen, and then click Deactivate.
A popup displays to confirm that your license has been deactivated.
