pltIPlot GetTipToTailSelectionMethod
Gets the selection method for the tip-to-tail curve.
pltIPlot_ctrl GetTipToTailSelectionMethod
HyperGraph Polar Plot/Tip to Tail functionality.
This command gets the selection method for the tip-to-tail curve. Returns a string indicating the selection method. Options include “none”, “all”, “displayed”, and “selected”.
None
None of the vectors is selected. Manual selection is not allowed.
All
All vectors are selected. Manual selection is not allowed.
Displayed
Based only on the displayed vectors, you can select vectors manually.
Selected
Based on all the vectors of the plot, you make selections.
This command is only valid for polar plots, vector mode.
Returns “all”, which means that all the vectors are included in the calculation and drawing of the tip-to-tail curve.
pltIPlot_ctrl  GetTipToTailSelectionMethod all
Returns an empty string.
