nanoFluidX
nanoFluidX
2022
  1. Home
  2. Validation Cases
    nanoFluidX validation cases.
  • What's New
  • nanoFluidX Overview
  • Preprocessing with SimLab
  • Run nanoFluidX
  • Postprocessing with ParaView
  • Simulation Guidance
  • Command Reference
  • Theory Manual
  • Validation Cases
  • Bibliography
Index
nanoFluidX
2022
nanoFluidX
  • What's New
    View new features for nanoFluidX 2022.
    nanoFluidX is a software to simulate single and multi-phase flows based on the Lagrangian Particle Method Smoothed Particle Hydrodynamics (SPH).
    Create a nanoFluidX model using SimLab.
  • Run nanoFluidX
    How to run a nanoFluidX model.
    How to postprocess nanoFluidX results using ParaView.
    Guidance on modelling specific usecases with nanoFluidX.
  • Command Reference
    nanoFluidX commands and parameters with examples.
  • Theory Manual
    Physics and Theory behind nanoFluidX
  • Validation Cases
    • Dam Break in 3D
    • Backward-Facing Step in 2D
    • Lid-Driven Cavity in 2D
    • Laplace Law for Surface Tension
    • Jet Impinging on a Spring-Loaded Plate
    • Experimental Validation - DSD Case
    • Experimental Validation - PIV Experiments
  • Bibliography
    References used throughout the nanoFluidX manual.
View All Altair Simulation Help
nanoFluidX
nanoFluidX
2022
  1. Home
  2. Validation Cases
  • What's New
  • Run nanoFluidX
  • Command Reference
  • Theory Manual
  • Validation Cases
  • Bibliography
Index
Validation Cases
  • Dam Break in 3D
