setVariableValue
Sets the value of the specified variable.
- Syntax
setVariableValue (variableName, variableValue , variableType)- Type
- Pulse Python API command.
- Description
- Sets the value of the specified variable. The listed variables must be defined in the process prior to running this command.
- Inputs
variableName: The name of the variable.- Version History
- 2022.1
#Load Pulse API
apidir = os.environ['ALTAIR_PULSE_API']
path = os.path.join(apidir,"python")
sys.path.append(path)
import pulse
pulse.setVariableValue("vel", 5.0, "Study")
