[1] Altair Visualizations
Altair Panopticon Real Time software supports a wide range of information visualizations, including our well-known Treemaps, Heat Maps, Scatter Plots, Horizon Graphs, and a wide range of other great visualizations designed for fast comprehension and easy interpretation of static, time series, real-time streaming, and historic data sets.
As no one visualization is ideal for every purpose, the appropriate visualization for the analytical task at hand must be used. Here are some general recommendations:
Analytical Task |
Recommended Visualization |
Read numeric values quickly |
Table / Pivot Table |
Performance against a KPI |
Bullet Graph, Tile, Ticker Tile, Donut Gauge |
Performance across a single variable for a small number of data elements, with different magnitudes |
Bar Graph, Tile, Ticker Tile |
Performance across a single variable for a small number of data elements, each with similar magnitudes |
Performance across a single variable for a large number of data items |
Performance across a single variable for a large number of data items, which have different importance values |
Performance across a hierarchical or grouped dataset |
Correlation between two categories of data |
Relationships between categories of data |
Correlation between two or more numeric data columns |
Geographic correlations of data |
Correlation over both a single numeric data column and various categories of data |
Trending performance across ordered categories |
Trending performance between two numeric variables |
Trending performance between three numeric variables |
Surface Plot (& 3D) |
Trending performance across time |
Time based Ranking |
Line Graph with Ranking Axis |
Time Based Contributions |
Time Based Correlations between time series |
Time Based Transactions |
Financial Time Series Distributions |
Auction Price & Interest/Volume Distribution |
Geospatial Area Densities |
Spread between two time series |
Version 2021.2.0/07.2022
