Duplicating an Export
When creating several similar exports, you can save time by using the first definition as the starting point for subsequent definitions. Monarch Classic makes this process easy.
Go to Export Design.
Display the properties of an export by selecting it on the selector.
Select Duplicate on the Export Design Ribbon. A copy of the currently selected export is automatically created.
The duplicate summary's default name is Export1.
Rename and edit the duplicate as required.
