Export Design
Export Design allows you to create or edit exports. You go to this mode within Export View.
The Export Design interface has the following elements:
       Element  |
       Description  |
       [ 1 ] Ribbon  |
       Display all the tools you need to work with an export definition. Refer to the Export Design Ribbon Quick Reference.  |
       [ 2 ] Selector  |
       Allows you to search for and/or select a specific export.  |
       [ 3 ] Source Panel  |
       Allows you to view or edit the properties of your source. This panel displays a different set of properties depending on the source you have selected (report, table or summary).  |
       [ 4 ] Output Panel  |
       Allows you to view or edit the properties of your output. This table displays a different set of properties depending on the output type you have selected..  |
To go to Export Design, select Export Design on the Export View Ribbon.
