Add Export Dialog
This dialog allows you to create an export definition and automatically add it to the project definition.
To access this dialog box, select Create Export on the Export Design ribbon.
Options
Field |
Description |
Source View |
Use this selector to select the source of the export. A source may be a report, a table, or a summary. |
Export File Type
Select an export file type from the list. Notes:
Run this Export |
This button is located at the top of the dialog box and allows you to run your export definition immediately. |
Add to Project |
This button is located at the top of the dialog box and allows you to save your export definition to your project. Once added to the project, you can run this export any time within the project. |
Edit Advanced Options |
This button is located at the top of the dialog box and allows you to specify advanced options. When you click this button you are brought to the Export Design window. Note that Advanced options depend on your export file type. |
Cancel |
Closes the Add Export dialog without creating an export. |
Help |
Displays this help topic. |
