Implement Fairshare
Implement fairshare to ensure that jobs are run in the order of how deserving they are.
Fairshare Scheduling Policy
Overview of the fairshare scheduling policy, associated parameters and the fairshare tree.
Fairshare ensures that jobs are run in the order of how deserving they are. A scheduler performs the fairshare calculations each scheduling cycle. If fairshare is enabled, all jobs have fairshare applied to them and there is no exemption from fairshare.
Fairshare can be configured for either primetime or non-primetime, or both. You cannot configure different behaviors for fairshare during primetime and non-primetime.
Fairshare Parameters
- Enable Fairshare
- Enables the fairshare algorithm, and turns on usage collecting. Jobs will be selected based on a function of their recent usage and priority (shares). Disabled by default.
- Fairshare Entity
- Specifies the entity for which fairshare usage data will be collected. Can be one of “euser”, “egroup”, “Account_Name”, “queue”, or “egroup:euser”. Not a prime option. Defaults to "euser".
- Fairshare Decay Factor
- Decay multiplier for fairshare usage reduction. Each decay period, the usage is multiplied by this value. Valid values: between 0 and 1, not inclusive. Not a prime option. Defaults to 0.5.
- Fairshare Decay Interval
- Time between fairshare usage decay operations. Not a prime option. Defaults to 24 hours.
- Fairshare Formula
- Specifies the mathematical formula to use in Fairshare calculations. It is composed of PBS resources as well as mathematical operators that are standard Python operators and/or those in the Python math module. When using a PBS resource, if resources_used.RESOURCE_NAME exists, that value is used. Otherwise, the value is taken from Resource_List.RESOURCE_NAME. Not a prime option. Defaults to "cput" (CPU time).
- Fairshare Shares for Unknown Entities
- The number of shares for the unknown group. These shares determine the portion of a resource to be allotted to that group via fairshare.
- Fairshare Enforce No Shares
- If this option is enabled, jobs whose entity has zero shares will never run. Requires fairshare to to be enabled. Not a prime option.
Fairshare Tree
Fairshare uses a tree structure, where each vertex in the tree represents some set of job owners and is assigned usage shares. Shares are used to apportion the partition’s or site’s resources. The default tree always has a root vertex and an unknown vertex. The default behavior of fairshare is to give all users the same amount of the resource being tracked. In order to apportion a partition’s or site's resources according to a policy other than equal shares for each user, you create a fairshare tree to reflect that policy.
| Keyword | Fairshare Entities | Purpose |
| euser | Username | Individual users are allotted shares of the resource being tracked. |
| egroup | OS group name | Groups as a whole are allotted shares of the resource being tracked. |
| egroup:euser | Combinations of username and group name | Useful when a user is a member of more than one group, and needs to use a different allotment in each group. |
| Account_Name | Account IDs | Shares are allotted by account string (Account_Name job attribute). |
| queue | Queues | Shares are allotted between queues. |
Allotting Shares in the Tree
You assign shares to each vertex in the tree. The actual number of shares given to a vertex or assigned in the tree is not important. What is important is the ratio of shares among each set of sibling vertices. Competition for resources is between siblings only. The sibling with the most shares gets the most resources.
Shares Among Unknown Entities
The root vertex always has a child called "unknown". Any entity not listed in the scheduler’s resource_group file will be made a child of "unknown", designating the entity as unknown. The shares used by unknown entities are controlled by two scheduling parameters Fairshare Shares for Unknown Entities and Fairshare Enforce No Shares.
The parameter Fairshare Shares for Unknown Entities controls how many shares are assigned to the "unknown" vertex. By default this parameter is unset and the "unknown" vertex has 0 shares. The children of the unknown vertex have equal amounts of the shares assigned to the "unknown" vertex.
The parameter Fairshare Enforce No Shares controls whether an entity without any shares can run jobs. If enabled, entities without shares cannot run jobs. If disabled, entities without any shares can run jobs, but only when no other entities’ jobs are available to run.
For a complete description about how to implement fairshare see Using Fairshare in the PBS Professional Administrator's Guide.
Use Fairshare
Configure fairshare scheduling.
