Timeseries Combination Settings
The Timeseries Combination visualization operates in a similar way to the table. Instead of multiple input variables becoming different columns in a table, they become different layers in the time series combination visualization. So unlike other visualizations it can display a large number of time series variables, which can be rendered as: Line, Candle Stick, Needle, OHLC, Spread, Stack and Stacked Needle.
1. Drag and drop timeseries columns from the Data Table pane to the Visuals variable drop area.
The column is added under the Visualizations tab list and by default, uses the Line graph and the Left Y-Axis alignment to the timeseries combination visualization.
NOTE |
The settings of the timeseries combination visualization will depend on the timeseries visualization that will be added. Refer to the corresponding Settings section to define their properties.
2. The properties that you can set will depend on the timeseries visualization that you will add, but the general settings include:
Set or select the following properties:
Setting |
Description |
Title |
Title of the visualization. |
Visualization |
If the visualization is incorrect, instead of deleting, you can just select another one in the Visualization drop-down list. The settings pane will be changed to display the corresponding properties of the selected visualization. |
Aggregate |
Aggregation method to be used. Default is Sum. |
Format |
The format that numbers will be displayed in. Panopticon uses the same formatting rules as Excel. |
Divide By |
Select the Divide By value to divide a number: · 1 · 1000 (by a thousand) · 10000 · 1000000 (by a million) · 1000000000 (by a billion) |
Y Axis Alignment |
The Y-Axis alignment: Left or Right. |
Color |
the Color variable that will be used for the column: · None · Shared Single · Custom Single · Column added to the Column variable |
Column/Value Column |
The timeseries column used for the visualization. If the dragged column is incorrect, instead of deleting, you can just select another column in the Column/Value Column drop-down list. NOTE: For the OHLC and Candle Stick Graph visualizations there are: Open Column, High Column, Low Column, and Close Column. |
3. Visual members can be set to display any of the following visualizations:
· Candle Stick or OHLC
· Grouped, Stacked or Standard Needle
Setting |
Description |
Size |
Select the Size variable that will be used. |
Shape |
Select the Shape value. |
Alpha |
Select the Alpha value. |
· Spread
Setting |
Description |
Reference Column |
The field that will be used as the reference line data series. |
Setting |
Description |
Reference Column |
4. The timeseries combination visualization includes an expanded Axes pane, which includes specification of the properties for both the Left and Right Y Axes.
Select or specify the following properties:
Setting |
Description |
Scale |
Determines whether the scale of the axis is Linear, Log, or Power. · Linear – a change between two values is based on addition e.g., 30, 60, 90, 120, 180, etc. · Log - a change between two values is perceived on the basis of the ratio of the two values or based on multiplication. Once selected, the Base control displays with the value of the common base for the logarithmic scale (i.e., 10).
For example: log10(x) represents the logarithm of x to the base 10 e.g., 1, 10, 100, 1000, etc. You can opt to enter a new Base
value then click NOTE: Value cannot be lower than 2. · Power – Works according to the SIGN(MEASURE)*LOG10(MAX(1, ABS(MEASURE))) formula. Works like the Log scale except it can handle negative values and every value between -1 and 1 is set to 0. For example for values between -100 and 100, the axis will be: -100, -10, 0, 10, 100 |
Inverted |
Determines whether the Y or Height axis is inverted. |
Show Title |
Displays an Axis Title label. |
Axis Bar Thickness |
The margin in pixels for the axis. If set to zero, the axis is removed. |
Preferred Tick Space |
The preferred space in pixels between the minor grid lines across the axis. |
Minor Grid Line |
How minor grid lines are drawn across the axis. Allowed values: · None · Dotted · Dashed · Solid |
Major Grid Line |
How major grid lines are drawn across the axis. Allowed values: · None · Dotted · Dashed · Solid |
Tick Format |
Set to From Variable to use the format string that is on the current variable displayed in the axis. Set to Metric Prefix to format the Tick labels in the numeric axes using the metric prefixes. |
Tickmarks |
Click
Enter the Value and the Label. Click
Range |
The visible range for the Left and Right Y-axis variables can either be calculated dynamically (Dynamic Range) or set between predetermined limits by selecting Fixed Range. This enables the Min and Max text boxes and populates them with default values taken from the data set. |
Independent Y-Axis Scaling |
Determines whether to have each visualization Y-axis in a cross tab automatically scaled independent of the others. |
Title and Format From |
The title and format of the Left and Right Axes based on the selected fields. |
to
add and set tick marks.
to
delete.
