/TH/MODE
Block Format Keyword Describes the time history for flexible body local modes.
| /TH/MODE/thgroup_ID | |||||||||
| thgroup_name | |||||||||
| var_ID1 | var_ID2 | var_ID3 | var_ID4 | var_ID5 | var_ID6 | var_ID7 | var_ID8 | var_ID9 | var_ID10 |
| Obj_ID1 | Obj_ID2 | Obj_ID3 | Obj_ID4 | Obj_ID5 | Obj_ID6 | Obj_ID7 | Obj_ID8 | Obj_ID9 | Obj_ID10 |
| thgroup_ID | TH
group identifier (Integer, maximum 10 digits) |
| thgroup_name | TH
group name (Character, maximum 100 characters) |
| var_ID1, ...n | Variables saved for
TH (see table below) (Character, maximum 8 characters) |
| Obj_ID1, ...n | Identifiers of the objects
to be saved (Integer) |
TH Output Keyword & Variables
| Keyword | Object Saved | Variables |
| MODE | Flexible body local modes | D, V, A |
Table of Available Variables - Part 2
| Keyword | Variable Group | Saved TH Variables |
| MODE | DEF | D, V, A |
Output for Flexible Body Modes
- D: modal displacement (participation of local mode to the flexible local displacement field)
- V: modal velocity (participation of local mode to the flexible body local velocity field)
- A: modal acceleration (participation of local mode to the flexible body local acceleration field)
- Available names are listed in the two
tables above.
In the first table, TH-variables are listed. If a TH-variable is requested, this variable is written.
In the second table, other variable groups are listed. If a variable group is requested, all the associated TH-variables are written at once.
