Reference: Marker
Command ElementModifies a marker element.
<Reference_Marker
id = "integer"
pos_x = "real"
pos_y = "real"
pos_z = "real"
a00 = "real"
a10 = "real"
a20 = "real"
a01 = "real"
a11 = "real"
a21 = "real"
a02 = "real"
a12 = "real"
a22 = "real"
rm_id = "integer">
</Reference_Marker>Attributes
- id
- The element identification number (integer>0). This number is unique to all Reference_Marker elements.
- pos_x, pos_y, pos_z
- The x, y, and z coordinates of the marker origin specified in terms of the global frame. pos_x defines the x-coordinate of the origin, pos_y defines the y-coordinate of the origin, and pos_z defines the z-coordinate of the origin.
- a00 a01 a02, a10 a11 a12, a20 a21 a22
- Elements of the transformation matrix defining the orientation of the
Reference_Marker with respect to the global
frame.
{a00 a10 a20} defines directions cosines of the x-axis.
{a01 a11 a21} defines directions cosines of the y-axis.
{a02 a12 a22} defines directions cosines of the z-axis. The nine elements define a 3x3, orthonormal matrix.
This means that the nine numbers must satisfy the following conditions:- The magnitude of each column is 1.
- Each column is orthogonal (perpendicular) to the other two.
- rm_id
- Specifies the ID of the Reference_Marker for which the position and orientation of the current marker are to be defined.
The following example modifies a Reference_Marker on a rigid body.
<Reference_Marker
id = "1012"
pos_x = "1.414"
pos_y = "3.14159"
pos_z = "1.61804"
a00 = "0."
a10 = "1."
a20 = "0."
a01 = "0.041630503"
a11 = "0."
a21 = "0.99913307"
a02 = "0.99913307"
a12 = "0."
a22 = "-0.04163050">
rm_id = 101
</Reference_Marker>
