Model ElementBeam defines a straight, massless beam of uniform cross section
acting between two markers, I and J, that belong to
two different parts.
The mass of the beam is lumped at the origins of the I and
J markers. The stiffness properties for the beam are derived
using the Timoshenko beam theory. The beam axis is assumed to be along the x-axis of
the J marker. The x-axis of the J marker is
also defined to be the neutral axis of the undeformed beam. The beam is assumed to
undergo small rotational deflections; large rotations are not supported.
Attribute Summary
| Name |
Property |
Modifiable by
command? |
Designable? |
| id |
Int
| label |
Str
| i |
Reference (Marker) |
Yes |
| j |
Yes |
| length |
Double () |
Yes |
Yes |
| ixx |
Double () |
Yes |
Yes |
| iyy |
Double () |
Yes |
Yes |
| izz |
Double () |
Yes |
Yes |
| area |
Double () |
Yes |
Yes |
| asy |
Double () |
Yes |
Yes |
| asz |
Double () |
Yes |
Yes |
| emodulus |
Double () |
Yes |
Yes |
| gmodulus |
Double () |
Yes |
Yes |
| cratio |
Double () |
Yes |
Yes |
| cmatrix |
Double (count=36) |
Yes |
| active |
Bool
Yes |
| force |
Double (count=3) |
Yes |
| torque |
Double (count=3) |
Yes |
| function |
Function () |
| routine |
Routine () |
| script |
Script () |
Usage
Beam (i=objmarker, j=objMarker, length=double, ixx=double, iyy=double, izz=double, area=Double, asy=double, asz=double, emodulus=double, gmodulus=double, optional_attributes)
Attributes
Beam defined by its properties.
- j
- Reference to an existing Marker object.
- Specifies the ID of the marker at which the force and moment is applied.
This is designated as the point of application of the force.
- The j attribute is mandatory.
- j
- Specifies the marker at which the reaction force and moment is applied.
This is designated as the point of reaction of the force. The x-axis of
J defines the neutral axis of the beam. The y-
and z-axes should be oriented along the principal axes of the cross
section (area products of inertial are zero).
- length
- Double
- Specifies the free length of the beam. This is the distance from the
origin of J to the origin of I.
The corresponding vector must lie along the x-axis of
J.
- The length attribute is mandatory.
- length > 0
- ixx
- Double
- Specifies the torsional stiffness shape factor for the cross section.
For circular sections, ixx is equal to the polar
moment of inertia. For non-circular sections, the torsional stiffness
constant is not equal to the polar moment of inertia. It's usually much
smaller because of warping effects associated with torsion.
- The ixx attribute is mandatory.
- ixx > 0
- iyy
- Double
- Defines the second moment of inertia of the beam cross sectional area
about an axis on the cross section that is parallel to the y-axis of
J.
- The iyy attribute is mandatory.
- iyy > 0
- izz
- Double
about an axis on the cross section that is parallel to the z-axis of
J.
- The izz attribute is mandatory.
- izz > 0
- area
- Double
- Defines the beam cross sectional area.
- The area attribute is mandatory.
- area > 0
- emodulus
- Double
- Specifies the Young's modulus of elasticity of the beam material. The
beam is assumed to be homogeneous in its material properties.
- The emodulus attribute is mandatory.
- emodulus > 0
- gmodulus
- Double
- Specifies the modulus of elasticity of the beam. This is related to the
Young's modulus and POISSON's ratio by the formula:(1)
where
is POISSON's ratio.
- The gmodulus attribute is mandatory.
- gmodulus > 0
- asy
- Double
- Specifies the shear area ratio in the y direction for Timoshenko beams.
This quantity accounts for shear deflection in the y direction. This is
defined as:(2)
- Qy is the first moment of the
cross-sectional area to be sheared by a force in the y direction.
lz is the cross section dimension
in the z direction. Iyy is the area moment of inertia
about the beam y-axis. To neglect shear deformation in the y-direction,
set ASY=0.
- The asy attribute is optional.
- asy ≥ 0
- When not specified asy=0
- asz
- Double
- Specifies the shear area ratio in the z direction for Timoshenko beams.
This quantity accounts for shear deflection in the Z direction. This is
defined as:(3)
- Qz is the first moment of
cross-sectional area to be sheared by a force in the z direction.
ly is the cross section dimension
in the y direction. Izz is the area moment of inertia about the beam
z-axis. To neglect shear deformation in the z-direction, set
asz=0.
- The asz attribute is optional.
- asz ≥ 0
- When not specified asz=0
- cmatrix
- 6x6 matrix specified as a list of 21 numbers in column or row ordered
format.
- Specifies the damping ratio as six by six symmetric
matrix.(4)
- This attribute is optional. When neither cmatrix or
cratio are specified, MotionSolve will assume it is zero.
- cratio
- Double
- Specifies the damping ratio for the beam. The beam damping matrix is
calculated by multiplying the beam stiffness matrix with the
cratio. In other words, [C] =
cratio * [K]
- A value of 0.01 (or 1%) is typically used for
cratio.
cratio are specified, MotionSolve will assume cratio
is zero.
- active
- Bool
- Select one from True or False
- True
- Indicates that the element is active in the model and it
affects the behavior of the system.
- False
- Indicates that the element is inactive in the model and it
does not affect the behavior of the system. It is almost as
if the entity was removed from the model, of course with the
exception that can be turned "ON" when desirable.
The attribute active is optional. When not
specified, active defaults to
True.
- force
- Double
- Specifies the translational preload of the Beam
object.
- The attribute is optional. When not specified, all the translational
preload will be zero.
- torque
- Double
- Specifies the rotational preload of the Beam
object.
- The attribute is optional. When not specified, all the rotational
Beam specified in a compiled user-written subroutine
- i
- Specifies the ID of the marker at which the force and moment are
applied. This is designated as the point of application of the force.
- The i attribute is mandatory.
- j
- function
- String
- The list of parameters that are passed from the data file to the
user-defined subroutine.
- The function attribute is mandatory.
- routine
- String
- Specifies an alternative name for the user subroutine. The name consists
of two pieces of information, separated by “∷”. The first is the
pathname to the shared library containing the function that computes the
force and its derivative with respect to relative displacement and
velocity. The second is the name of the function in the shared library
that does the computation.
- An example is:
routine=”/staff/Altair/engine.dll∷myBeam
- ”/staff/Altair/ engine.dll
is the DLL.
- “myBeam” is the function within this
DLL that performs the calculations.
Beam specified in a Python function.
- i
- j
- function
- String
- routine
- It could either point to a callable function in Python or be the name of
a python function (String).
- The routine attribute is mandatory.
- script
- The path to the script which contains the python callable pointed by
routine. When routine points to a callable object, script will be
neglected.
- The script attribute is optional.
Optional Attributes – Available to all description methods.
- id
- Specifies the element identification number. This number must be unique
among all the Beam objects in the model.
- This attribute is optional. MotionSolve will
automatically create an ID when one is not specified.
- Range of values: id > 0.
- label
- String
- Specifies the name of the Beam object.
- This attribute is optional. When not specified, MotionSolve will create a label for you.
Create a BEAM given the geometry and material properties
below.
The example demonstrates a short, squat beam that is used as a connector between two
rigid bodies. The beam connects
Reference_Marker 37 on
Rigid_Body 3 and
Reference_Marker 47 on
Rigid_Body 4. The properties of the beam are as follows:
- Length of the beam = 57.55mm.
- Radius of circular cross section = 10mm.
- Material = steel.
- The damping ratio is 0.001.
The Force_Beam definition for these specifications:
beam0 = beam (label="beam0", i=marker37, j=marker47, length=57.55, ixx=15707.96,iyy=7853.982, izz=7853.982, area=314.1593, emodulus=2E5, gmodulus=7.692308E4, asy=1.2,asz=1.2, cratio=0.001)
- See Properties for an
explanation about what properties are, why they are used, and how you can extend
these.
- For a more detailed explanation about Beam, see
the Comments in Force: Beam.
