Convert Time Cut Results into FieldView Particle Path File Format
Time cut results are produced using the TIME_CUT_OUTPUT type from AcuTrace.
acuTransTrace -to fieldview -fvopt time_cut,steadyacuTransTrace -to fieldview -fvopt time_cut,unsteadyMore information regarding the use of AcuTransTrace is available in the AcuSolve Programs Reference Manual.
