Thermal Event
Define a Temperature (Linear Static) loadcase.
Figure 2. View new features for HyperWorks 2021.
Set up your sessions in HyperWorks and create report templates.
Rapidly change the shape of the FE mesh without severely sacrificing the mesh quality and create, edit, and apply shapes for subsequent design optimization studies.
HyperMesh composites modelings.
The Design Space environment is dedicated to topology optimization model build and setup. It facilitates rapid model creation by generating the voxel design space for a number of different use cases.
Many essential utility tools using HyperWorks-Tcl have been developed over the years to support Aerospace customers. A few tools have been collected and upgraded to be compatible with this release.
Use the marine tool set to streamline the creation of properties and 1D stiffener mesh using the info read from Marine CAD tools.
Use Squeak and Rattle Director tool set to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
Technology and problem evaluation approaches used in SnRD.
Explore SnRD Pre-Processing User Interface.
Use Setup Group to setup evaluation lines and define loadcases.
Use Import feature to import a model, DTS and material database file.
Use Define Interface tool to create, import and edit geometric lines.
Use Create E-Lines tool to create evaluation lines at component interfaces.
Use Manage E-Line tool to review and manage E-lines.
Setup loadcases to solve and extract results.
Define a Modal Transient (MTRAN) loadcase.
Define a Static (Linear Static) loadcase.
Create Single Point Constraints (SPCs).
Setup a Variability Study to analyze and examine the squeak and rattle risks caused by manufacturing variations
Use Manage E-Points to modify local system collectors and evaluation points.
Evaluate Loadcase and export solver deck.
Explore SnRD Post Processing User Interface.
Use of Altair Ziegler SnR Material Database.
Figure 2. (c) 2021. Altair Engineering Inc. All Rights Reserved.
