HyperCrash
Parameter
Parameter
Previous topic Next topic Expand/collapse all hidden text
Parameter
This section shows you how to do the following:
hmtoggle_arrow1Define a Parameter
You can define a parameter (/PARAMETER) as follows:
•Integer (INT).
•Real (REAL).
•Integer expression (INT_EXPR): Defines an expression of INTEGER parameters.
•Real expression (REAL_EXPR): Defines an expression of REAL parameters.
hmtoggle_arrow1Create a Parameter
1.From the main menu, select RADIOSS Tools > Parameter.
The Parameter card tab opens.
2.From the Notebook window, right-click, and then select Create New > REAL, INT, REAL_EXPR or INT_EXPR.
parameter_create_radioss
An ampersand (&) indicates a parameter.
3.The appropriate material subpanel opens for you to enter the following:
•For Title*, enter a new name.
•For [PARAM_NAME], enter a parameter name.
•For [PARAM_VALUE], enter a parameter value.
parameter_create_new_radioss
4.Save, Close or Cancel your entries.
hmtoggle_arrow1Import and Export a Parameter
1.From File, select Export (or Import) > RADIOSS.
The RADIOSS output tab opens.
2.Enter a new filename (example: *_export_0000.rad), and then click OK.
3.Locate and open the file that was just created.
4.In the exported file, each parameter is defined in a RADIOSS Block Keyword as you see below:
parameter_name_radioss
hmtoggle_arrow1Cross-Reference a Parameter
1.From the Parameter tab, select a parameter.
2.Click the Cross Reference icon:
crossreference_radioss
The Cross-Reference dialog opens and displays the parameter that has been cross- referenced along with the attribute (field) associated with the parameter:
crossreference_radioss_2
hmtoggle_arrow1Associate and Disassociate a Parameter
Associating a Parameter
1.Right-click a parameter, and then select Select Parameter as below:
parameter_crossreference_radioss
The Select in Model dialog opens:
parameter_crossreference_info_radioss
2.From the Select in Model dialog: select a parameter, click OK, and then Save.
Disassociating a Parameter
1.From the appropriate card tab, select a parameter.
2.Right-click a parameter, and then select Disassociate Parameter.
Only the value remains intact.
parameter_disassociate_radioss
3.Click Save.
