HyperCrash
Transformation
Transformation
Transformation
The Transformation option on the RADIOSS Tools menu lets you create, delete, edit, or cross reference a Transformation card (/TRANSFORM).
In the Transformation panel, right-click to open the context menu, and then select an option.
context_menu_transformation
Create a New Transformation
1.Select Create New from the context menu, then select from the following list:
•User Defined - the USER card panel appears
•Translation - the TRA card panel appears
•Rotation - the ROT card panel appears
•Symmetry - the SYM card panel appears
•Scaling - the SCA card panel appears
2.Click to edit fields and right-click in applicable fields for more options.
3.Click to expand the sub-menus and make selections from these menus as applicable.
transformation_panel
4.Click Save or Cancel when you are finished creating the card.
