HyperCrash
Information Options
Information Options
Previous topic Next topic Expand/collapse all hidden text
Information Options
hmtoggle_arrow1Finding node information
There are two options available in which to find node information:
•select a node
•enter a node identification number
To select a node:
1.Click infoNodeByPoint-24 on the toolbar.
2.Pick a node in the graphic window: the information about the node and the linked parts are displayed in the message window.
3.If needed, pick another node.
4.When finished, click Cancel in the Dialog menu bar to stop the selection.
To enter a node ID:
1.Click infoNodeByKeyboard-24 on the toolbar.
2.In the new sub-window, enter a node identification number.
3.Click OK or right-click the mouse button to validate the selection: the information about the node and the linked parts are displayed in the message window.
4.Click Cancel to cancel the selection.
hmtoggle_arrow1Finding element information
There are two options available in which to find element information:
•select an element
•enter an element identification number
To select an element:
1.Click infoElemByPoint-24 on the toolbar.
2.Pick an element in the graphic window: the information about the element and the linked parts are displayed in the message window.
3.If needed, pick another element.
To enter an element ID:
1.Click infoElemByKeyboard-24 on the toolbar.
2.In the new sub-window, enter an element identification number.
3.Click OK or right-click the mouse button to validate the selection: the information about the element and the linked parts are displayed in the message window.
hmtoggle_arrow1Finding part information
Note:To accept selection(s), either press Enter, click Yes or right-click the mouse button; or select Cancel.
There are four options available in which to find part information:
•select a part
•drag a box
•pick parts and add to previous selection
•drag a box and add to previous selection
To pick a part:
1.Click selectByPointToTree-24 on the toolbar.
2.Pick parts in the graphic window.
To drag a box:
1.Click selectByBoxToTree-24 on the toolbar.
2.Select parts by dragging a box in the graphic window:
•The default box is rectangular.
•Use the SHIFT key to define a polygon box.
To pick parts and add to a previous selection:
1.Click selectByPointAddToTree-24 on the toolbar.
To drag a box and add to a previous selection:
1.Click selectByBoxAddToTree-24 on the toolbar.
hmtoggle_arrow1Finding object information
There are two options available in which to find object information:
•select an object
•enter an object identification number
To pick an object:
1.Click infoFEObjectByPoint-24 on the toolbar.
2.Pick an object in the graphic window: the information about the object and the linked parts are displayed in the message window.
3.If needed, pick another object.
To enter an object ID:
1.Click infoFEObjectByKeyboard-24 on the toolbar.
2.In the new sub-window, enter an object identification number.
3.Click OK or right-click the mouse button to validate the selection: the information about the object and the linked parts are displayed in the message window.
hmtoggle_arrow1Finding distances and angles
Distances
1.Click distanceBetweenNodes-24 on the toolbar.
2.Pick two nodes in the graphic window: the distance between the two selected nodes is displayed in the message window.
3.If needed, pick two other nodes to find another distance.
Angles
1.Click angleBetweenNodes-24 on the toolbar.
2.Pick three nodes in the graphic window: the angle between the three selected nodes is displayed in the message window.
3.If needed, pick three other nodes to find another angle.
See also
Display Options
