HyperCrash
Display Options
Display Options
Previous topic Next topic Expand/collapse all hidden text
Display Options
Control the Graphic Display
•Click refresh-24 (or CTRL + F) to refresh the screen.
•Click hc_fit_display (or CTRL + R) to fit the displayed parts to the screen in the graphic window.
•Click viewAxisOrientationDropDown-24  and choose an option from the drop-down menu to display the model in a predefined view:
viewAxisOrientationXY-24
to display XY view (same as F9 key)
viewAxisOrientationYZ-24
to display YZ view (same as F10 key)
viewAxisOrientationXZ-24
to display XZ view (same as F11 key)
viewAxisOrientationPerspective-24
to display XYZ (perspective) view (same as F12 key)
•Click displayElemsTransparencyLevel-24 to adjust the transparency level of visible parts displayed in order to control the control the visibility of other selected visible parts (same as the plus (+) and minus ( - ) keys).  This icon is used in conjunction with another corresponding module transparency icon.
For example, to control the visibility of one part of a model, select the part in the Tree panel, click the Isolate Tree Selection with Transparency icon (displayTreeHighlight), then click displayElemsTransparencyLevel-24 and use the slider to adjust the transparency of all the rest of the parts.
How Do I ...
hmtoggle_arrow1Display entities in the tree
Button
Behavior
selectbypointtotree-24
select parts to display them in the tree
selectByBoxToTree-24
draw a box around parts to display them in the tree.
selectByPointAddToTree-24
select parts to add to the display in the tree.
selectByBoxAddToTree-24
draw a box around parts to add to the display in the tree.
SHIFT key + Page Down
will select from the selected part downwards
SHIFT key + Page Up
will select from the selected part upwards
hmtoggle_arrow1Select entities to display
•Click displayPartsAll-24 to display all the parts of the model.
•Click selectionTreeDropdown-24 and select:
selectionTreeAdd-24
to add the parts selected in the tree in the graphic window
selectionTreeAddFit-24
to add the parts selected in the tree and fit in the graphic window
selectionTreeRemove-24
to mask the parts selected in the tree from the graphic window
selectionTreeIsolate-24
to isolate the parts selected in the tree in the graphic window
•Click displayElemsAddDropdown-24 and select the element type to add to the display:
shellElemsGeneral-24
the shells
springElemsGeneral-24
the springs
beamElemsGeneral-24
the beams
trussElemsGeneral-24
the trusses
solidElemsGeneral-24
the solids
sph_element_icon
the SPH
•Click displayElemsRemoveDropdown-24 and select the element type to mask from the display:
the shells
the springs
beamElemsGeneral-24
the beams
the trusses
the solids
sph_element_icon
the SPH
•Click displayElemsIsolateDropown-24 and select the element type to isolate:
the shells
the springs
beamElemsGeneral-24
the beams
the trusses
the solids
sph_element_icon
the SPH
•Click displayFreeNodes-24 to toggle between displaying and masking the free nodes from the graphic window.
•Click displayGeneralReverse-24 to reverse the displayed and masked parts in the graphic window.
hmtoggle_arrow1Choose the entity display mode
•Click displayElemsModeDropdown-24  and select the display mode:
elemsPoints-24
node cloud display
elemsFeatures-24
feature line display
elemsWireframe-24
wireframe display
elemsShaded-24
shaded display
elemsShadedWithFeatures-24
shaded with feature lines display
elemsShadedWithMesh-24
shaded with lines display
•Click displayElemsRotateModeDropdown-24  and select the view mode for the view simplification:
elemsPoints-24
node cloud display
elemsFeatures-24
elemsWireframe-24
wireframe display
elemsShaded-24
shaded display
displayElemsRotateModeLock-24
set to display mode
•Click displayElemsSimplifyReverse-24 to toggle between displaying and masking element details.
•Click displayElems3dWireframeSkinReverse-24 to toggle between displaying and masking all the segments of the solid elements (by default only the external skin is displayed).
hmtoggle_arrow1Select parts in the graphic window display
Button
Behavior
selectPartByPointUnmask-24
pick parts to unmask them completely.
selectPartsConnectedByPart-24
(or CTRL + F) and pick a part. The parts in node proximity to the selected one are displayed.
selectPartBy2PointsUnmask-24
(or CTRL + Z) and pick two nodes in the graphic window. HyperCrash will display all the parts connected to the two picked nodes.
selectPartHide-24
pick parts to mask them from the graphic window.
selectPartHideByBox-24
define a box to mask parts from the graphic window.
selectPartIsolate-24
pick parts to isolate and display in the graphic window.
selectpartisolatebybox-24
define a box to isolate and display parts in the graphic window.
hmtoggle_arrow1Select elements in the graphic window display
Button
Behavior
selectElemsConnectedDropdown-24
select one of the following the icons from the drop-down menu. The elements connected to the selected one(s) are displayed.
selectElemsConnectedByElem-24
pick one element in the graphic display
selectElemsConnectedByElems-24
pick several elements in the graphic display
selectElemsConnectedByBox-24
select an element with a box in the graphic display
selectElemsModeDropdown-24
select one of the following the icons from the drop-down menu. Then select elements in the graphic window:
selectElemsByPointMask-24
pick elements to mask them in the graphic window
selectElemsByBoxMask
define a box to mask elements in the graphic window
selectElemsByBox
define a box to isolate and display only the elements in the box
selectElemsByTwoNodesUnMask-24
pick two nodes to display the elements that are in the the proximity of the selected nodes
See also
Information Options
