HyperCrash
To save the projected stamping result
1.Enter a first root file name in the Output file name window.
or
Click Browse to select a directory and an already existing file.
2.Select the shell formulation type:
•Old formulation (RADIOSS version 3.1)
•New formulation (RADIOSS version 4.1) — recommended.
3.Select the output value.
4.Select the number of integration points for the parts by clicking increaseDecrease.
5.Click Write to save the files, Y000 and Y111.
A second Browse window appears.
6.Set a second root name for the D00 and D11.
This second root name must be different from the first one. A geometric output is usually requested if IGTYP is greater than 0 (see the flag IGTYP in the card /IOFLAG in the D00 file).
