HyperCrash
To display the projected stamping result
1.From the Menu Bar, select Process > Results Mapper.
2.Select the Contour tab.
3.Select the parameter to display in the window Type of value:
•Thickness
•Plastic strain (select the integration point by clicking increaseDecrease )
•Stress tensor (select the integration point by clicking increaseDecrease )
4.Click reviewGeneral-24 to view the selected parameter.
Range modification
1.Enter a value in the field, Min value:.
2.Enter a value in the field, Max value:.
3.Click displayTreeIsolate-24 to update the display selection.
4.Click displayTreeRemove-24 or displayTreeAdd-24 to set the minimum and the maximum value of the model.
Clear display
Click selectionClear-24 to clear the display in the graphic window.
Number of colors
Click increaseDecrease to increase or decrease the number of colors.
