HyperCrash
To modify a glue
To modify a glue
To modify a glue
Note:To accept selection(s), press Enter, click Yes or right-click the mouse button; or select Cancel.
1.From the Menu Bar, select Connections > Glue > Modify.
2.Select only one glue (see Glue Selection for more information).
3.Click reviewGeneral-24 to display the glue and to open the modification menu.
•In the Part sub-window:
Button
Behavior
selectPartBy2PointsUnmask-24
displays all the parts in the neighborhood of the selected glue.
selectPartGeneral-24
pick parts in the graphic window to add them to the glue definition.
selectPartByBox-24
select parts by box in the graphic window to add them to the glue definition.
selectEntityFromTree-24
adds the selected parts of the tree in the glue definition
selectionclear-24
deselects the parts that define the glue
•In the Location sub-window, it is possible to change the glue location. (See element, node, or line for more information).
•In the Property sub-window:
-Click Prop. Name and select a property (beam type spring property - type 13) in the common property database.
-Enter the name of the HyperCrash property file (beam type spring property - type 13).
4.Click Save to save the modified glue; or
Click Cancel to cancel the glue modification.
5.Click Close to close the menu.
Glue selection
Button
Behavior
treeSelectUnselectAll-24
select all the glues.
10_unselectalluncreated
select all the uncreated glues.
selectGeneral-24
pick glues in the graphic window to select them.
selectSpotweldByBox
select glues by box (use the SHIFT key to use a polygon box).
pick parts in the graphic window to select all the glues linked to those parts.
selectPartByBox-24
select parts by box (use the SHIFT key to use a polygon box) to select all the glues linked to those parts.
Click on the glue line in the listing window to select it. Several glues from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys.
automaticGeneral-24
automatically recreate the "uncreated" glues. In the message window, a message explains why this glue cannot be created.
See also
Glue
Export File
