HyperCrash
To modify or delete an added mass
1.From the Menu Bar, select LoadCase > Added Mass > Modify.
2.Select added masses using one of the following methods:
Button
Behavior
treeSelectUnselectAll-24
select all the added masses
automaticGeneral-24
automatic correction of unspread masses
selectGeneral-24
pick the arrow for the added mass in graphic window to select it. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
selectSpotweldByBox
select added masses by box (use the SHIFT key to use a polygon box).
selectPartGeneral-24
pick parts in the graphic window to select all the added mass applied to those parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel.
selectPartByBox-24
select parts by box (use the SHIFT key to use a polygon box) to select all added masses applied to those parts.
Click the added mass line in the listing window to select it. Several added masses from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys.
3.Select only one added mass and click reviewGeneral-24 for the option to do any of the following:
•Change the added mass name.
•Select or unselect nodes or parts (see Node and part selection).
•Modify the added mass components (see Property).
4.Click deleteGeneral-24 to delete the selected added mass.
5.Answer the question in the pop-up dialog window with Yes or Cancel.
6.Click Save to save the modified added mass; or
Click Cancel to cancel the added mass modification.
7.Click Close to close the menu.
Go to
Added Mass
