HyperCrash
To modify an accelerometer
1.From the Menu Bar, select Data History > Accelerometer > Modify.
or
If the Data History panel is open, select Accelerometer > Modify from the pull-down menu.
2.In the Accelerometer to modify list, click the accelerometer.
3.Click reviewGeneral-24 to display the accelerometer in the graphic window.
It is possible to:
•Modify the accelerometer's name by setting a new name in the Accel. name field and validating with Ok.
•Change the accelerometer position (see Node selection).
•Modify the reference axis (see Reference axis).
•Modify the cut-off frequency (see Cut-off frequency).
4.Click Save to save the accelerometer modifications; or
Click Cancel to cancel the accelerometer modifications.
5.Click Close to close the menu.
