HyperCrash
To delete an accelerometer
1.From the Menu Bar, select Data History > Accelerometer > Modify.
or
If the Data History panel is open, select Accelerometer > Modify from the pull-down menu.
2.Select accelerometers:
•Click treeSelectUnselectAll-24 to select all the accelerometers.
or
•Click the accelerometer line in the listing window to select it. Several accelerometers from this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys.
3.Click deleteGeneral-24 to delete all the selected accelerometers.
4.Answer the question in the Dialog menu bar with Yes or Cancel.
5.Click Close to close the menu.
