HyperCrash
To modify a property
1.From the Menu Bar, select Model > Property.
2.Go to the Tree window.
3.Select the property from the tree.
4.Click the displaytreeisolate-24 Isolate Tree Selection icon.
5.Go back to the Property panel.
6.Click selectPartGeneral-24 to select parts.
7.Click reviewGeneral-24 to view the selected parts.
The property parameters appear in the panel.
8.Modify the parameters.
9.Click Save.
10.Click Close to close the Property panel.
Property modification
If only one property is selected, HyperCrash will automatically open this property in order to modify it.
1.Click selectPartGeneral-24 and pick parts in the graphic window to select or deselect them.
2.Click treeAddEntity-24 to add or remove the parts from the tree selection.
3.Enter the different values in the fields for the property.
•Set the value or the property name.
•Click the toggle button to switch options ON or OFF.
•Click the button for the function to set or modify a function.
•Set the number for the function needed and click Ok.
4.Click databaseAdd-24 to save this property (as a RADIOSS input deck file):
•In the new sub-window, select the directory to save the property to (left area part).
•Enter the name of the property to save.
•Select OK to save the property or Cancel to cancel the save.
5.Click Save to save the property creation; or
Click Cancel to cancel the property creation.
6.Click Close to close the menu.
