HyperCrash
To create a property
1.From the Menu Bar, select Model, then Property.
2.Below are the available options to sort the property list:
•Click entityIDGeneral-24 to sort the property list by ID number.
•Click entityGeneral-24 to sort the property list by name.
•Click 10_entityType to sort the property list by type.
•Click encryptionlock to sort the property list by status.
3.Under Choose Property Law, select a property.
4.Click selectPartGeneral-24 and pick parts in the graphic window to select or deselect them.
5.Click treeAddEntity-24 to add or remove the parts from the tree selection.
6.Enter the different values in the fields for the property.
•Set the value or the property name.
•Click the toggle button to switch options ON or OFF.
•Click the button for the function to set or modify a function.
•Set the number of the function needed and click Ok.
7.Click databaseAdd-24 to save this property (as a RADIOSS input deck file).
•In the new sub-window, select the directory to save the property to (left area part).
•Enter the name of the property to save.
•Select OK to save the property or Cancel to cancel the save.
8.Click Save to save the property creation; or
Click Cancel to cancel the property creation.
9.Click Close to close the menu.
