HyperCrash
Creating Nodes
Creating Nodes
Creating Nodes
•From the Menu Bar, select Mesh Editing > Node > Create.
or
•If the Mesh Editing panel is already open, select Node > Create from the pull-down menu in the panel.
To create node(s) between two other nodes:
1.Select the Nodes Between Nodes radio button.
2.In the Number of Node(s) field, enter the number of nodes to be created between two nodes, or use the increaseDecrease buttons.
3.ClickcreateNode-24 and in the graphic window, pick the two boundary nodes.
The nodes are displayed in red.
4.Click Save to save the created nodes; or
Click Cancel to cancel node creation.
5.Click Close to close the menu.
To create a node at the center of 3 nodes:
1.Select the Node Center of 3 Nodes radio button.
2.ClickcreateNode-24 and in the graphic window, pick the 3 nodes.
The nodes are displayed in red.  When the third node is picked, the new center node is calculated.
3.Click Save to save the created nodes; or
4.Click Close to close the menu.
To create a node at specific coordinates
1.Select the Coordinates radio button.
2.Fill in the x, y, and z fields.
3.Click displayValueByKeyboard-24 to display the node in the graphic window.
To copy a node
1.Select the Copy radio button.
2.Select the Translate tab.
mesh_edit_copy
3.Select Coord. or Dir./Length radio button.
4.Fill in the vector coordinates X, Y and Z.
5.Click the button to select the nodes to duplicate.
6.Click vectorcreateby2nodes-24  to pick 2 nodes.
7.Click reviewgeneral-24 to display the translation.
8.Click Save to save the created nodes; or
9.Click Close to close the menu
See also
Merge nodes
Disconnect nodes
Delete nodes
