HyperCrash
Disconnecting Nodes
Disconnecting Nodes
Disconnecting Nodes
•From the Menu Bar, select Mesh Editing > Node > Modify.
or
•If the Mesh Editing panel is already open, select Node > Modify from the pull-down menu in the panel.
Two options are available to disconnect nodes
•Disconnect all the selected nodes.
disconnec_01.zoom50
disconnec_03.zoom50
•Disconnect only the nodes between different parts.
disconnec_01.zoom50
disconnec_02.zoom50
1.Click the Discon. radio button to activate.
2.Click either the Disconnect Nodes or Disconnect Common Nodes between part radio button.
mesh_node_disconnect
3.Select the nodes to disconnect:
Button
Behavior
selectGeneral-24
pick nodes in the graphic window, and then answer the question in the Dialog menu bar with Yes or Cancel.
selectByBoxAdd-24
add nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
selectByBoxRemove-24
remove nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
selectPartGeneral-24
pick parts in the graphic window, and then answer the question in the Dialog menu bar with Yes or Cancel
selectPartByBoxAdd-24
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
selectPartByBoxRemove-24
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
treeAddEntity-24
add the parts selected in the tree
treeRemoveEntity-24
remove the parts selected in the tree.
4.Click Save to disconnect the nodes; or
Click Cancel to cancel node disconnection.
5.Click Close to close the menu.
