HyperCrash
To create a boundary condition
1.From the Menu Bar, select LoadCase > Boundary Condition > Create.
2.Enter a name in the Boundary condition creation field and validate with Ok.
3.Make a selection from the radio buttons: Added, Removed or See
4.In the Selections sub-window, select nodes using the different tools from the Selection folder.
Button
Behavior
selectGeneral-24
pick nodes in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar.
ellipse_icon
add/remove object by ellipse selection.
selectByBoxAdd-24
add nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
selectByBoxRemove-24
remove nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
selectPartGeneral-24
pick parts in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar.
selectPartByBoxAdd-24
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
selectPartByBoxRemove-24
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box).
treeAddEntity-24
add the parts selected in the tree.
treeRemoveEntity-24
remove the parts selected in the tree.
5.In the Reference Axis sub-window, a skew frame can be defined for the boundary condition:
•Click the Reference Axis folder.
•Define the reference axis using the different tools from the Reference Axis folder.
6.Make a selection from the radio buttons: Global, Moving Local or Fixed Local.
7.Click Tx and/or Ty and/or Tz to fix the translation degrees of freedom (selected). Click it once more to release the degree of freedom (not selected).
8.Click Rx and/or Ry and/or Rz to fix the rotation degrees of freedom (selected). Click it once more to release the degree of freedom (not selected).
9.Click Save to save the created boundary condition; or
Click Cancel to cancel the boundary condition creation
10.Click Close to close the menu.
Go to
Boundary Condition
