HyperCrash
To check an interface
1.From the Menu Bar, select Contact Interfaces > Check.
In the interface list, those with a green interface have a correct definition, the orange ones have to be checked, and the red ones have a bad definition.
2.In the listing window, click the contact interface line to select one interface.
3.Click reviewGeneral-24 to display the interface.
4.Check the error or warning message in the Message window.
5.Using the pop-up function (right button on the mouse in the interface list window):
•Click See Incompat. Kinematic Cond. on Slaves to view slave nodes of tied interfaces with incompatible kinematic conditions.
•Click See Slave nodes no proj. to view slave nodes which cannot be projected on the master surface of the tied interface.
•Click See Slave nodes in Multiple Interfaces to view slave nodes which are included in several tied interfaces.
•Click See Interfaces. Slave Nodes in Master Surface to view slave nodes of tied interfaces which are also defined in the master surfaces of the same or other tied interfaces.
•Click Check penetrations selected interfaces
•Click Time History >> Add or Remove
6.Modify the interface Selection sub-window.
7.Modify the interface Properties sub-window.
8.Click Save to save the modified interface.
or
Click Save + Sym. to save the interface and automatically create its symmetric: the slave side becomes the master and the master side becomes the slave (not available for a Self-Impact interface).
or
Click Cancel to cancel the contact interface modification.
9.Click Close to close the menu.
Go to
Contact Interface
