HyperCrash
To create an interface
1.From the Menu Bar, select LoadCase > Contact Interface.
2.Right-click to access the context menu and make a selection from the list.
3.Click the Choose Contact drop-down list and select an interface type.
4.Click the Selection sub-window.
5.Select one of the following:
•Self-Impact
•Slave to define the slave group of the interface.
•Master to define the master group of the interface.
•See to display the selected surfaces: the master surfaces in blue, and the slave ones in red.
6.Group definition:
•Define the group using the different tools from the Selection tab.
7.Click the Properties tab.
8.Assign a Title.
9.Define the different required parameters.
10.Click Save to save the created interface.
or
Click Save + Sym. to save the interface and automatically create its symmetric: the slave side becomes the master, and the master side becomes the slave (not available for a Self-Impact interface).
or
Click Cancel to cancel the interface creation.
11.Click Close to close the menu.
Go to
Contact Interface
