Card Formats
Two card formats are supported namely column-based and colon-separated. This is relevant to users who externally generate Feko input files and can be ignored by users using EDITFEKO to modify the cards.
Column Based Format
Figure 1. Column based card format in EDITFEKO. The numbers above the table (1, 6, 10, 15, 20...110) indicate the columns.
Colon Separated Format
The colon separated format separates the individual integer and real parameters by a colon character. It is a less restrictive format than the column-based format. Unlike the column-based format, integer and real input fields are not restricted to 5 or 10 characters respectively. Note that the card name is still located in columns 1 and 2. The name is followed by a colon in column 3. The rest of the card has no spacing limitations.
DP: S1 : : : : : #x : #y : #z
BP: S2 : S2 : S3 : S4
