Creating a Cartesian Graph
Create a Cartesian graph by searching and navigating the documentation.
Search1 for
Cartesian in the integrated help.
The results returned in response to the Cartesian query includes Cartesian (object).
- Double-click CartesianGraph (object).
View the CartesianGraph (object).
Note: Since there can be multiple Cartesian graphs in the project, the CartesianGraph object is part of a collection.
Figure 1. A snippet of the CartesianGraph object which shows the Parent collection list. -
Click the CartesianGraphCollection hyperlink to navigate
to the CartesianGraphCollection description.
Figure 2. A snippet of the CartesianGraphCollection which shows the Method list.Note: View the :Add method in the Method list.Note: CartesianGraphCollection resides under the Application object.
Figure 3. A snippet of the CartesianGraphCollection object which shows Usage locations. -
Create the Cartesian graph using the following syntax.
my_graph = app.CartesianGraphs:Add() -
Run the script created up to this point to view the
progress in the GUI.
Figure 4. The result in the POSTFEKO GUI after running the script.
