Creating Data Extract from Elasticsearch 6.x
The Elasticsearch 6.x connector allows you to connect and access data from an Elasticsearch cluster using Transport Client.
NOTE |
· The Elasticsearch 6.x connector supports Elasticsearch 6.x versions. · Elasticsearch 5.x and 6.x connectors will not work in a single Panopticon Visualization Server instance due to conflicting Elasticsearch API dependencies.
1. On the New Data Extract page, select Elasticsearch 6.x in the Connector drop-down list.
2. Follow steps 3 to 4 in Elasticsearch 6.x to define the connector settings.
3. Click
to save and display the details
of the data extract.
4. Click
then
to display the data preview.
