Altair® Monarch®
Summary All Fields Window
Use this window to view or modify the properties of all fields (keys, items, and measures) in a summary.
Note: if you want to add or remove fields, use the Add/Remove Fields window.
Displaying the All Fields window
  1. Go to Summary Design.
  2. Select a Summary from the Summaries selector. The summary's properties are displayed on the Summary Window.
  3. Select All Fields on the Summary Design ribbon.
  4. Select a field on the All Fields selector. The field's tabs and properties are displayed.
Notes:
  • The General tab will indicate what type of field is currently selected: key, item or measure.
  • A different set of tabs display for each field type.
  • Refer to the following for more information on the tabs and properties for each key type:
