Monitor the status of your jobs, filter the job view, view job details, monitor memory and core utilization, view
a list of job files, or perform job actions.
Open a remote session in a new window and work on the interactive application.
You can also connect to a remote session from the Job
Monitoring page or the Job Summary page. Refer to Connect to a Remote Sessions
for more information.
Click the Sessions tab located in the upper left-hand of the page.
A sessions list is displayed.
Figure 1. Session List
Right click a session name and click Open Session in New
Tab
A remote session of the interactive application is opened in a new
window. Figure 2. Opened Remote Sessions
Note: By default, the timeout interval when a session is opened is set to
unlimited. The default configured timeout value is set to 120 minutes (2
hours) for a remote session and it is displayed in session list timeout
column while viewing the session. Time out will start when the session is
closed, and the remaining time is displayed in session list timeout column.
Click to view the session options.
Note: The session control displayed is a floating panel which can be
moved.
Figure 3. Session Control
The session control options are displayed. Figure 4. Session Control Options
The following session options are displayed:
- open the session in desktop
- change the
resolution
- copy text to clipboard
modal
- expand the session in full screen
- collapse the session from full
screen. This option is displayed only when the session is expanded in
full screen.
