Upload a File
Upload a file stored on your local machine to the remote server.
- Click the Files tab located in the upper left-hand of the page.
- Using the file system tree on the left, navigate to the location where you want to upload the file.
Click Upload File.
Figure 1. Upload a FileA File Upload dialog box is displayed. -
Browse and select the file to upload.
If you are uploading a zip file, an option is provided to extract the contents of a zip file.
Note: This option is displayed when you are uploading a single zip file.Note: Select Don't Ask Again to disable the confirmation message. - Click Yes to extract the contents of the zip file.
Click Open.
You can also drag the file from your local system to the folder to upload.
Figure 2. Drag the File to UploadThe file starts to upload. A progress bar is displayed in the lower right-hand side of the page indicating the progress of the upload. A notification message is displayed when the upload is complete.Tip: When you hover over the progress bar, you will get an option to terminate the file upload.
