Opening a Monarch Complete File via the File Open Dialog
A standard File Open dialog allows you to select a Monarch Complete file (model, project, or workspace) on your hard drive or network.
Find the file or folder that you want to open.
Model: *.xmod/*.dmod
Project: *.xprj/*.dprj
Workspace: *.dpwx
Double-click the file or folder to open it, or select the file and click Open.
Depending on the file you want to open, Monarch Data Prep Studio will help you look for the following:
Refer to Working with Monarch Complete Files for more information on what you can do after opening a Monarch Complete file.
Note:
When you open a Monarch Complete file Monarch Data Prep Studio brings you directly to the Prepare window, and displays a node corresponding to the model you have opened. When you open other sources, Monarch Data Prep Studio usually brings you to the Preview Window.
