Altair® Monarch®
Appending Tables from the Prepare Window
From the Prepare Window, you can append tables by selecting them from the Table List (use Ctrl+click to select more than one table), right-clicking on your mouse, and then selecting an Append operation from the context menu that displays.
Note that:
  • Different options will produce different results.
  • In some cases, the order in which you select tables to append will affect the result.
Steps
  1. In the Prepare window table list, select the tables you want to append. (Ctrl+click on the tables to select more than one table.)
  2. Right click, select Append Tables, and the then select the append method:
    • Match Columns on Name
    • Match Columns on Name and Type
    • Match Columns on Order
    • Match Columns on Order,  Name and Type
Note: If you want more control with defining the append, consider using the Edit Append dialog.
Examples: Appending Tables by Matching on Name
Example 1
Consider the following tables to append:
Data Processing Table
Dept
Last Name
First Name
Emp ID
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
Marketing Table
Department
Last Name
First Name
Emp ID
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting Table
Department
Last Name
First Name
Emp ID
Date
Gender
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
Matching Columns on Name produces the following result:
Dept
Last Name
First Name
Emp ID
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
April
Anne
1597429
10/23/1993 0:00
F
Banning
David
1607768
12/18/2003 0:00
M
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Daley
William
1587390
1/30/1993 0:00
M
Georges
William
1596792
6/4/2005 0:00
M
In this example, the Department column values of the Marketing and Accounting tables are not included because they do not match the name of the first column in the first table.
Note that Monarch Data Prep Studio will consider the first table as the basis for appending succeeding tables.
Example 2
If you append tables in a different order, i.e.:
Marketing Table
Department
Last Name
First Name
Emp ID
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting Table
Department
Last Name
First Name
Emp ID
Date
Gender
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
Dept
Last Name
First Name
Emp ID
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
You get this result:
Department
Last Name
First Name
Emp ID
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
Bass
Andrew
1593211
3/18/1999 0:00
M
Bittner
Herb
1597596
3/18/2005 0:00
M
Bittner
Martha
1604193
12/18/2001 0:00
F
Example 3
Note that the position does not matter when you append by Matching Columns on Name:
Marketing Table
Department
Last Name
First Name
Emp ID
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting Table
Department
Last Name
First Name
Emp ID
Date
Gender
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
Last Name
First Name
Emp ID
Date
Department
Gender
Bass
Andrew
1593211
3/18/1999 0:00
Data Processing
M
Bittner
Herb
1597596
3/18/2005 0:00
Data Processing
M
Bittner
Martha
1604193
12/18/2001 0:00
Data Processing
F
Department
Last Name
First Name
Emp ID
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
Examples: Appending Tables by Matching on Name and Type
When you Match on Name and Type, Monarch Data Prep Studio will append only tables with columns that have the same name and data type. This append follows the same logic as Matching in Name, but with the added condition that column data types match.
Example 1
Department
Last Name
First Name
Emp ID (number)
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
Marketing Table
Department
Last Name
First Name
Emp ID (text)
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting Table
Department
Last Name
First Name
Emp ID
(text)
Date
Gender
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
The result will be::
Department
Last Name
First Name
Emp ID (number)
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
Marketing
April
Anne
10/23/1993 0:00
F
Marketing
Banning
David
12/18/2003 0:00
M
Accounting
Aldridge
Jeff
10/13/1995 0:00
M
Accounting
Daley
William
1/30/1993 0:00
M
Accounting
Georges
William
6/4/2005 0:00
M
In this example, the Emp ID column values of the Marketing and Accounting tables are not included because they do not match the data type of the Emp ID column in the Data Processing table.
Example 2
If you have the following tables:
Department
Last Name
First Name
Emp ID (number)
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
Marketing Table
Department
Last Name
First Name
Emp ID (text)
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting Table
Department
Last Name
First Name
Employee  ID
(number)
Date
Gender
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
Department
Last Name
First Name
Emp ID (number)
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
Marketing
April
Anne
10/23/1993 0:00
F
Marketing
Banning
David
12/18/2003 0:00
M
Accounting
Aldridge
Jeff
10/13/1995 0:00
M
Accounting
Daley
William
1/30/1993 0:00
M
Accounting
Georges
William
6/4/2005 0:00
M
In this example, the Emp ID column values of the Marketing and Accounting tables are not included because they do not match either the name or the data type of the Emp ID column in the Data Processing table.
Example: Appending Tables by Matching on Order
When you match on Order, Monarch Data Prep Studio will append only tables with columns that match on position. Monarch Data Prep Studio will ignore column names and data types.
Dept
Last Name
First Name
Emp ID
(number)
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
Marketing Table
Department
Last Name
First Name
Emp ID
(number)
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting Table
Department
Last Name
First Name
Emp ID
(text)
Date
Gender
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
If:
  • The Department column of the Data Processing table has a different name, and
  • The Emp ID column of the Accounting table has a different data type (text instead of number)
The result will be:
Dept
Last Name
First Name
Emp ID
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
In this example, all values of Emp ID from all tables are included since we are only matching on Order and Name.
Appending Tables by Matching on Order, Name, and Type
When you Match on Order, Name, and Type, Monarch Data Prep Studio will append only tables with columns that match on position, name, and type.
Example 1
Dept
Last Name
First Name
Emp ID
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
Marketing Table
Department
Last Name
First Name
Emp ID
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting Table
Department
Last Name
First Name
Emp ID
Date
Gender
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
If columns in all tables have matching data, types, Append Tables > Match on Order, Name, and Type result will be:
Dept
Last Name
First Name
Emp ID
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
April
Anne
1597429
10/23/1993 0:00
F
Banning
David
1607768
12/18/2003 0:00
M
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Daley
William
1587390
1/30/1993 0:00
M
Georges
William
1596792
6/4/2005 0:00
M
Note that Monarch Data Prep Studio will consider the first table as the basis for appending succeeding tables. If you append tables in a different order, i.e.:
Marketing Table
Department
Last Name
First Name
Emp ID
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting Table
Department
Last Name
First Name
Emp ID
Date
Gender
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
Dept
Last Name
First Name
Emp ID
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
You get this result instead:
Department
Last Name
First Name
Emp ID
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
Bass
Andrew
1593211
3/18/1999 0:00
M
Bittner
Herb
1597596
3/18/2005 0:00
M
Bittner
Martha
1604193
12/18/2001 0:00
F
Example 2
Dept
Last Name
First Name
Emp ID
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
Marketing Table
Department
Last Name
First Name
Emp ID
Date
Gender
Marketing
April
Anne
1597429
10/23/1993 0:00
F
Marketing
Banning
David
1607768
12/18/2003 0:00
M
Accounting Table
Department
Last Name
First Name
Emp ID
Date
Gender
Accounting
Aldridge
Jeff
1592784
10/13/1995 0:00
M
Accounting
Daley
William
1587390
1/30/1993 0:00
M
Accounting
Georges
William
1596792
6/4/2005 0:00
M
If:
  • The Emp ID columns of the Accounting table has a different data type (text instead of number)
An Append > Matching on Order, Name, and Type result will be:
Dept
Last Name
First Name
Emp ID
Date
Gender
Data Processing
Bass
Andrew
1593211
3/18/1999 0:00
M
Data Processing
Bittner
Herb
1597596
3/18/2005 0:00
M
Data Processing
Bittner
Martha
1604193
12/18/2001 0:00
F
April
Anne
1597429
10/23/1993 0:00
F
Banning
David
1607768
12/18/2003 0:00
M
Aldridge
Jeff
10/13/1995 0:00
M
Daley
William
1/30/1993 0:00
M
Georges
William
6/4/2005 0:00
M
Related Links
