Export Images for all Computed Results
Generate images of all computed results and export to folder. Use this batch generation of images to accelerate report preparation or as part of an automatic report generation process.
Export computed results to image by clicking Project > Report Generator > Generate Result Images.
Figure 1. An example of results exported to image.
Figure 2. The Export results to images dialog.
Folder for images
Browse to the folder location where the images will be exported. Each exported image is given a file name that indicate the result.
Map view
The aspect ratio of the map view is fixed and cannot be modified. You can either adapt the resolution or define a scale for the resulting bitmap. When using the scaled export, the resolution in dpi is set to the resolution of the screen (for example, 96 dpi). Additionally, the scale in the map view can be exported to the bitmap.
Note: Incorrect scale sizes may result in large bitmap files.
Legend view
The legend view can also be exported. The legend can either be saved to a separate file or in the same file as the map view. The height in pixels of the exported legend will be the same height as of the main bitmap.
