Multiplex4
Multiplexer block for four input connectors
Modelica/Blocks/Routing
The output connector is the concatenation of the four input connectors.Note, that the dimensions of the input connector signals have to beexplicitly defined via parameters n1, n2, n3 and n4.
mo_n1 | n1 | Dimension of input signal connector 1 | Scalar | |
mo_n2 | n2 | Dimension of input signal connector 2 | Scalar | |
mo_n3 | n3 | Dimension of input signal connector 3 | Scalar | |
mo_n4 | n4 | Dimension of input signal connector 4 | Scalar |
mo__modifiers/value | Value |
u1 | implicit | Connector of Real input signals 1 | input | 1 |
u2 | implicit | Connector of Real input signals 2 | input | 2 |
u3 | implicit | Connector of Real input signals 3 | input | 3 |
u4 | implicit | Connector of Real input signals 4 | input | 4 |
y | implicit | Connector of Real output signals | output | 1 |
